Son1990 said:Pics of that will follow shortly. CPU will be attached via custom made wooden bracket.
Captain Slug said:The GPU container base is drilled and will be tapped soon for metric2 bolts. These containers were designed with low material costs in mind, but without having to compromise on using aluminum.
Yes it is, but silver solder was used and it will hold fine since there are no butt joints.{PMS}fishy said:It looks soldered together. Is that the case?
If so it really needs to be brazed.
Captain Slug said:Yes it is, but silver solder was used and it will hold fine since there are no butt joints.
-aDaM^ said:Ya, youll need oxy/acelene setup for brazing.
{PMS}fishy said:No you don't.
