jb you need to have a little patience, you are going to have a difficult time getting stable if you just keep punching numbers in and hoping for the best. If you are going to use the multi to Oc then pust it the way you were .5 at a time a V Core when necessary and test. Then do the same with the FSB, set multi to stock bump fsb to 205, keep RAM, HT Link and NB Freq in line and test. Some boards just can't do big FSB numbers, you need to figure out what the limit is on yours. Using the process I said above I found that on my ASUS M5A99X EVO board I cannot set the FSB above 230, no matter what. On my Chrosshair V Formula I haven't found a limit yet.
Sorry if I came off overly abrupt, I was writing that previous post when I saw you made the big jump to 240. Seems if you are on the correct path now. You are in good hands with Johan and Trents. BTW Trents nice to see you posting, WB.
I just finished up a set of benches from 4.1Ghz to 5.4Ghz with an FX-6300 and I just went back and looked at my captures to see what was the Vcore that was used at 235x17.5 = 4.1Ghz-ish. Since I was testing the least Vcore that I could use to run Cinebench 11.5, the Vcore I found was 1.368V as indicated by HWMonitor and CPUz on the CPU Tab.
Knowing I was testing "least" Vcore to run and finish the CPU Test of Cinebench 11.5, I would expect you to need very close to 1.368Vcore to run 227x17.5 = 3972.5 Mhz. It takes more Vcore to run and be stable in Prime 95 Blend mode than to run a simple benchmark about 97% of the time.
RGone...
No he's not saying that, he's pointing out what voltages he needed to run cinebench. At the clocks he specified he is saying that it isn't considered stable and probably would fail prime because it's just enough CPu V Core to pass the benchmark. Running a benchmark is usually easier then passing 2 hours of prime, which will in most cases, requires more CPU V Core. Therefore in most cases just because he was able to run Cinebench it does not mean it's stable for 24/7 use.Rgone are you saying that i should no use Prime and use something like cinebench?
okay thanks mandrake i thought he might be insinuating that prime is overkill or something like that.No he's not saying that, he's pointing out what voltages he needed to run cinebench. At the clocks he specified he is saying that it isn't considered stable and probably would fail prime because running a benchmark is usually easier then passing 2 hours of prime. Therefore in most cases just because he was able to run Cinebench it does not mean it's stable for 24/7 use.
Okay so llc has no submenu when i enable it. Auto/disabled/enabled. The bios desc. Says for am3+ to enable it so i did but im guessing it was auto enabled before when it was on auto. So what do you think I should do next. Roll back to 3.8ghz where it was not motherboard/cpu throttling to protect its self. The thing is this morning it was at 3.8 before with only the multiplier no tinkering with the fsb. In that case which is the better overclock?
