- Jan 12, 2012
5100 Mhz at 1.46 2 hours Prime stable is a hell of a chip.
i have the same chips fx9590 with asus sabertooth fx990 rev 2.0 running @5100.34 voltage set to 1.46 and never experienced temperature rising high and hot.prime 95 blend test my temps only reached 52 the most.still perflexed about this heat thing on fx 9590 by the way my cooler corsair h110i and psu 1300watts evga super nova.im a new member you can check my profile
H100i ?
I also have very heavy doubts even at 1.4600v.
My experience was at stock 4.7ghz and load claiming v-droop at 1.416v heat soaked 120.2 custom loop in no time while having standard ambient temperatures 72-75f.
http://www.overclockers.com/forums/showthread.php/768459-FX9590-unstable
Probably ought to watch here too then.
I have a feeling you'll never see any pics.
Can you please guide me to upload the pics while I'm blend testing it to shut down fan boys and dispell the rumors about this chip, right cooling minimum of 1000watts psu and configuration this fx9590 delivers one quick note I got this chips directly from amd
- - - Updated - - -
Also let me add I'm running 4 sticks of tridentx240016gb
Curious to see Cpu-z P-states on Aval0412's processor.
To do this, return rig to stock auto. Open Cpu-z, go to about tab and save report. Then open txt report file scroll down to p-state section and copy paste to forum post. It just that EASY! Please and thanks you. It will help with building a data base for AMD FX-9590 processors.
Where's ZEN?
Fan boys? Avail0412, just an FYI of why there are people skeptical about 1.46 V stable on an H110i. We have seen plenty of these chips come through here. We also have a few that own them, see above. I've personally yet to see a single 9590 run stable with that little voltage. I'm not saying it's impossible, just saying I've yet to see one. The whole 1000w Psu isn't accurate though, the power draw of that chip is likely higher then the stated 220w AMD claims. That said the whole system with 1 Gpu at stock clocks isn't drawing anywhere near 1000W of power. Only if one is overclock both the Cpu and Gpu on extreme cooling would one need that much power or if running multiple Gpu's.Can you please guide me to upload the pics while I'm blend testing it to shut down fan boys and dispell the rumors about this chip, right cooling minimum of 1000watts psu and configuration this fx9590 delivers one quick note I got this chips directly from amd
- - - Updated - - -
Fan boys?
Here's how.View attachment 173234
Here's how to add pics.View attachment 173234
What'd you do bro?.......you're pink.
He actually added the Mr Clean to my title recently which I hadn't noticed until it was pointed out to me today. So I told him to highlight it in pink. Haha.What'd you do bro?.......you're pink.
If it was Johan your titles would be ~MadcAtsQuiDEateR~ & BeaMed mE Up
