To a man here we all have custom water cooling when we OC to these upper OC limits
I guess in a way, most of us that help in here try and tell it like it is for the long-haul. No watered-down pablum about how less cooling can still work okay with these heat monster FX processors and certainly so when ALL 8 cores come into use when overclocked like we all seem to do. Real c00l is in. Real c00l is just about the only way to have a super relationship with an FX-9590 unless you can keep your hands out of the bios and use the FX-9590 only as AMD intended it to be used when they brought the FX-9590 to market.
RGone...
Two important quotes in these two posts these Fx chips just run hot!!!! Even on a full custom loop I only run 4.7 @ 1.46875 Cpu V because the voltage and heat produced for 4.8 is just too much for my liking.
I shut down four cores and run 5ghz 1.5250v manually from time to time. Stability tested some 7 hours on it. Max temp just over 60c. At 4.7 ghz all 8 cores does about the same heat output.
Increasing core clocks seems to produce a lot of heat just as if you over volted it.
Ddr4 is overrated IMO and not worth the $.
i seem to recall people saying the same thing about ddr3 when it first came out.
it just needs to develop/get adopted a bit more, and then it will be better, i think
Sure they finally sort of sort it all out...but woe to he who jumps first at the elevated price and waits thru the sorting. That is the sucky part.
RGone...
Samena, if you look at my signature I have both a I 7 4770k and an AMD Fx 8350. The 4770k @ 4.4 because mine is a heater and I cannot get it any higher on custom water because of temps. As I've said I run 4.7 on my 8350 on a custom loop as well. Both setups have SSD's. I use the Fx 8350 as my daily rig. Yes the I7 is faster in benchmarks and in most cases Gaming but for some reason I choose to use the Fx 8350 daily. It just feels like it runs smoother to me. Once you get the heat under control with the Fx chips they really are pretty good processors and heck of a lot of fun to Oc, if that's your thing.I'd like say thanks for the help you guys have provided to me over the course of this OC saga (lol it was defintiely needed). I've gathered and learned much from this experience. I hate to say it, but it seems like intel is winning the battle. I've bought nothing but AMD ever since I have started building my own PCs. I've always been a bit of an AMD fanboy I guess you could say. I'm wondering if i should have went Intel this time though, as there are no DDR4 motherboards out there for AMD as of yet, which is much to my disliking. Hopefuly AMD can push this issue in the future and I will upgrade this machine, but until then I'll just enjoy the ride. Thanks again!
Deeyam. That is about the best and most information about an FX-9590 that I have had the privilege to lay my eyes upon. I have a working knowledge of an FX-8 core at 4.7GHz with ALL the cores on. HoT and it surely explains why many have problems using FX-9590 at even the stock 4.7GHz speed.
Shrimpy my man you have just related the FX-9590 heat monster in a way that makes the whole problem just about crystal clear. Thank you sir.
RGone...skisterzzzzzzzzzzzzzzzz
...post above Bassnut. I guess in a way, most of us that help in here try and tell it like it is for the long-haul. No watered-down pablum about how less cooling can still work okay with these heat monster FX processors and certainly so when ALL 8 cores come into use when overclocked like we all seem to do. Real c00l is in. Real c00l is just about the only way to have a super relationship with an FX-9590 unless you can keep your hands out of the bios and use the FX-9590 only as AMD intended it to be used when they brought the FX-9590 to market.
Let me say a little to background the review/article below. There are those of us that spend possibly too much time in searching background information and results from users from all over. I may fit such category.
I watched the release of the FX-9590 processor. I read a 'lot' of reviews. Most reviews were the same old pablum from most reviewers. However if you have followed a lot of my writing you will remember I said no reason to buy the FX-9590 since it did n0t appear to be 'super silicon' and thus a prime candidate for overclocking. I said just a very very few reviews of the FX-9590 told the real truth.
Well hokiealumnus was one of the few that told it like it truly was about the FX-9590. How there was way much heat to contend with and that even with his custom water cooling loop he was barely able to reach 5.0GHz with ultimate stability.
HIS older/original water loop is used as the comparison for the loop he is testing in the review below. Yes on Intel in the review below but he is pleasingly surprised at the less temps he sees now with the EK L360 Kit which is not even the bad boy kit from EK.
So now if you have paid attention you know the more complete background behind the review below. His original FX-9590 review was done with his older loop and now he tested a new loop that is; by a good bit, better than his original loop and makes the EK non-Extreme kit tested below a very good candidate for cooling an FX-9590. This is not to say that there may not be other possible solutions, but at least here is a solution that has 'history' surrounding it.
I, as can many of the others that hang around in the AMD forum sections, can spec out a complete loop for ourselves. But a kit is often a better option for beginners. Especially a kit that is not just another AiO kit that is just barely entry level water cooling.
Article by hokiealumnus @ OCF done in Feb 2014.
EK WaterBlocks L360 Water Cooling Kit Review
You are now returned to your regularly scheduled programming. Ole Faht out.
RGone...
So basically, you now have a max clockspeed of 4.7, at twice the heat, and twice the price of a 8350 that you could have had 4.7 on anyway.if finaly solved the problem : my config is amd fx9590 , coolmaster water cooling, hyper fury x 1866 mhz 16 gb, asus sabertooth r2.0 990 fx
first load up bios defaults, restart, then disable amd turbo mode, disable cool and quiet, let the rest as it is. dram frequenzy i choose 1866 mhz and it works fine without freezing anymore !
Great job.
Many people have stated that any AMD 8 core at 4.7 GHz will consume as much juice and make as much heat as the 9590 at 4.7 GHz. From my anecdotal evidence on this forum I don't buy that. I agree with you Mr. Scott.
No stability testing required at 4.7ghz with 5ghz turbo.
While I watch many people try and OC to 4.7ghz and struggle with heat, the same can be had with a stock 9590. The difference is there is no stability testing required to run a FX-9590 at 4.7ghz.
Is a FX-9590 faster than a FX-8350/70? Yes, and by a considerable margin. Even at stock while overheating and meeting it's first P-state of 4.5ghz (all 8 cores), it's still ahead of that 4.2ghz turbo (only 4 cores) of the FX-8350.
