Good and accurate information in your...
...post above Bassnut. I guess in a way, most of us that help in here try and tell it like it is for the long-haul. No watered-down pablum about how less cooling can still work okay with these heat monster FX processors and certainly so when ALL 8 cores come into use when overclocked like we all seem to do. Real c00l is in. Real c00l is just about the only way to have a super relationship with an FX-9590 unless you can keep your hands out of the bios and use the FX-9590 only as AMD intended it to be used when they brought the FX-9590 to market.
Let me say a little to background the review/article below. There are those of us that spend possibly too much time in searching background information and results from users from all over. I may fit such category.
I watched the release of the FX-9590 processor. I read a 'lot' of reviews. Most reviews were the same old pablum from most reviewers. However if you have followed a lot of my writing you will remember I said no reason to buy the FX-9590 since it did n0t appear to be 'super silicon' and thus a prime candidate for overclocking. I said just a very very few reviews of the FX-9590 told the real truth.
Well hokiealumnus was one of the few that told it like it truly was about the FX-9590. How there was way much heat to contend with and that even with his custom water cooling loop he was barely able to reach 5.0GHz with ultimate stability.
HIS older/original water loop is used as the comparison for the loop he is testing in the review below. Yes on Intel in the review below but he is pleasingly surprised at the less temps he sees now with the EK L360 Kit which is not even the bad boy kit from EK.
So now if you have paid attention you know the more complete background behind the review below. His original FX-9590 review was done with his older loop and now he tested a new loop that is; by a good bit, better than his original loop and makes the EK non-Extreme kit tested below a very good candidate for cooling an FX-9590. This is not to say that there may not be other possible solutions, but at least here is a solution that has 'history' surrounding it.
I, as can many of the others that hang around in the AMD forum sections, can spec out a complete loop for ourselves. But a kit is often a better option for beginners. Especially a kit that is not just another AiO kit that is just barely entry level water cooling.
Article by hokiealumnus @ OCF done in Feb 2014.
EK WaterBlocks L360 Water Cooling Kit Review
You are now returned to your regularly scheduled programming. Ole Faht out.
RGone...
