- Apr 20, 2004
- JAX, Mississauna
Regardless of the problems getting to that CPU speed it all seems pretty good now. Good luck and happy computering.
RGone...
RGone...
whats up with the 300mhz variance in speed i wonder?
We've all been wondering.
That's hard to say. When in question the motherboard bios and then software readouts.... I always do a fresh install of windows just to test the software.
Right?!
What can I provide you guys with to figure this variance out?
I am curious as to what that software is that shows the lightning bolt in the task bar.
Driver & Tools
There are 3 download servers available on ASUS Download Site - Global, China and P2P. Each server provides exact the same content no matter where you download from, except for the speed which you are connected to.
OS
Windows 8.1 64bit
25 files found
Qualified Vendor List (1)
BIOS (10)
Version 1604
Description SABERTOOTH 990FX BIOS 1604
1.Improve system stability.
2.Support new CPUs. Please refer to our website at: http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us
File Size 2.29 MBytesupdate 2012/10/24
Download from Global
Version 1503
Description SABERTOOTH 990FX BIOS 1503
2.Enhance compatibility with some USB devices.
File Size 2.28 MBytesupdate 2012/10/10
Version 1304
Description SABERTOOTH 990FX BIOS 1304
File Size 2.27 MBytesupdate 2012/07/20
Version 1208
Description SABERTOOTH 990FX BIOS 1208 <--- currently using
1.Improve Improve system stability.
File Size 2.27 MBytesupdate 2012/05/29
