pc hits 5.1 with turbo core at less temp :XOK on my phone and these old eyes..... well....... from what I can see your OC'd to 4.7 / 4.8ghz under load. If that's what that says then......
For 4.7ghz / 4.8ghz that's not a bad temp with all core firing full tilt for an AIO cooler on your package. You need to work on your socket temp though..... 74*C is pushing it.
BTW Shrimp said in a previous post that this cpuneeds 1.525v to run stable after oc. Maybe you're planning on having me raising it slowly once temp is more supresssed?
You could try a simple overclock like this one here. I have all the green on with a slight bump in reference clock.
You can never mind the memory speeds, this is just a quick example. Notice the 4.8ghz clock, 5.1ghz turbo and the cpu core never went over 1.5125v.
all the green?
I should have thought about the zip tie thing while i was at the cpu store a bit ago. fml
- - - Updated - - -
here's the hwinfo and prime for the 2hr test i ran while i was out...
