Sort of stable, you just said that P95 won't run. IBT "regular" on standard isn't enough. Mr scott is right more power to all partsTry the stability test in AMD OD see if it'll pass that. Not that it's a holy grail since it's still weak IMO but likely a better indicator than what you're doing now.. Running 5.0 needs more CPU_NB volts even when mem and NB speed haven't changed. The IMC has more work to do every time you raise the core speed. Scotty and I have seen a lot of FX in action power is where it's at, and heat can't forget that.
