- Jul 14, 2013
- Holed up in Branford, CT
Your cpu doesn't idle at 15c. That has been beaten to death. Have you stress tested that overclock? Hyper 212 EVO is kind of a low end cooler. Especially if you run a six or eight core.
What is your power supply?when I came back to my PC it had turned off.
Are you suggesting the CPU running at full load will only stay cool if the room temp is cool? I am talking about airflow, for instance if it's hot outside but there is a high wind chill factor; without your TShirt on you'll probably catch a cold
Also what I mean by idling at 15c ... If I leave my PC on just the desktop HWmonitor reads 15c temp for the CPU and stays around there.
My PSU is the Corsair RM750 mate.
Thanks
HWmonitor will not show any semblance of accuracy unless your cpu has a load and it hits around 40C.
Lol. When it's hot outside and the wind blows, you feel cooler because you sweat and the wind uses that as a catalyst to remove heat from your body. Your computer doesn't sweat.Are you suggesting the CPU running at full load will only stay cool if the room temp is cool? I am talking about airflow, for instance if it's hot outside but there is a high wind chill factor; without your TShirt on you'll probably catch a cold
I know a bit about physics just not much about hardware monitor.
Ok I will rephrase it, Hardware monitor displays around 15c when I am not running anything.
Your temps now will be different a couple months from now.
I brought a machine I had in my cold basement upstairs into a room in the house proper. I figure it was low to mid 40's in the basement. Upstairs it is about 68. My nice, stable overclock on a 6300 immediately failed. I dialed it back from 4.8 GHz to 4.6 GHz.
Yeppers. An easy 200mhz loss from temps to high.
Amazing how ambient temps comtroll our pc And overclocks.
Thanks!!
