I would first check in the tank to see if any fuel lines popped off their fittings. If you were in there something could have gotten bumped, reusing fuel line clamps, etc..
The fuel pump only cycles as a function check before the bike starts. It's supposed to run for a couple seconds and pressurize the fuel system until you start it.
Starter: You should hear the engine turning over. If you were in the tank pulling the filter, the odds are that's where you'll find the problem. Not always, but often enough.
