Blend stresses ram also. Check your timings and voltage.
Pretty low vcore for 4.7
15 minutes isn't enough of any stress test to confirm stability, 2 hours minimum. If you're failing Blend I'd bet it's due to the stress that 16g of ram is putting on the Imc. What are the entire specs of the system and what is the Cpu Nb voltage set at. I also agree with Scotty 1.36 V is pretty low for 4.7 Ghz.
many 8 core cpu's take 1.404 to run 4.7, test it at 1.38, if it runs longer and fails raise it another bump.
at 16 gigs raise the cpu/nb voltage a bump or two.
and a lot of these 6 and 8 cores don't like 4 sticks of ram.
just saw the spd, you have 2x8 gigs.
The best answer is, it passes fft but not blend because it isn't stable. You should be able to get your nb frequency up to 2600 with 1.3v and you probably need way more voltage for 4.7 What are you cooling with? You're temps don't look quite right to me.
Not too hot, I would expect them to be lower at that voltage though. I would also expect there to be less of a spread between socket and core temps than i'm seeing.
Any reason why there's that big of a difference in my core and socket temps?
The temp/voltage relationship isn't an exact science. A lot of that depends on the CPU and it's "leakage"
Typically a CPU that can run faster at lower voltages is a low leaker and will run a tad hotter.
Your socket temps can be helped with some extra fans. One blowing down onto the VRM heatsink around the CPU and one on the back of the board blowing at the socket itself. You'll gain 10c that way.
As for the original question, a touch more V_Core and I would set the ram at 1.65v, just a touch over stock voltage of 1.6v
Here's some examples of fans
View attachment 172654View attachment 172655
