3600 15-15-15 1.40V
3866 16-16-16 1.40V ( couldn't run any tighter till 1.55V+ )
Just picked up 4 sticks of trident z 3200 C14. I'm hoping they do well when paired with the 7920x. In terms of stability testing, is memtest86 good enough? I would like to do a pre-boot test.
Better check it in Windows. Something like AIDA64 memory+cache test or some other tests that are using a lot of memory work better than memtest86. It's because memtest is checking cell by cell while is not fully loading memory and memory controller. However 2 of these kits should work fine. I had one and was working fine on ASUS X299 TUF2.
On new platforms it doesn't really matter. Maybe is a bit faster but can't see big difference even in quick bandwidth/latency tests. Above some frequency 2N will be required to keep stability.
Btw, nice bandwidth. I guess that more CPU cores are bumping it a bit as on 10 cores I couldn't pass ~105GB/s read.
As I mentioned in other thread, I'm checking Taichi XE now but there is only one official BIOS and early beta which was on the board was acting pretty much the same.
AIDA64 uses about ~97% of free RAM ( regardless how much RAM you have ). Test runs without any limits but after about 2-3h it usually won't crash. At least for me if it passed ~3h test then wasn't crashing later. Since there is still a bit of free RAM then you can use PC but it will be slower. When it crashes then will show red screen and error. When OS freeze or show blue screen then after restart AIDA will show info that last test didn't finish correctly.
