Ok, here is an update.. better late than never (picture at end of this post, my first time with a pic, hope it goes)..
Before I get into the temps, just look at the space on the rear/top where the 5th fan should go, it's empty cuz there is no way in heck I can fit a 140mm in there due to the two cpu power cables on the top left of the mobo, unless I don't want to do cable management. This mobo barely fit into the case as it is, I had no idea the Phanteks was such a tight fit (but I do love it). I believe I can force a 120mm fan into the top slot though, I tried already and I think it'll fit but I need a better fan than I have, probably will get the same type as the 140mm.
If you guys see anything else I should do let me know.
About the temps. So idle, not much diff at all, it still jumps between 40C and 50s, right now as I type (that's all I'm doing), it's about 43C and jumps to 49C on occasion.
With the P95 blend test, it goes into the low 70s and the PC is still quiet, but the torture core test, CPU max heat, it goes into sounding like a vacuum right away, but at least this time it doesn't hit the 95C limit, it goes to 92C right away and stays there (I only let it for a few mins, it fluctuated between 91C and 93C).
At that temp on the torture test, Ryzen Master said I'm hitting 4.1GHz all cores, I guess that is acceptable for a torture test, now I do see that there is nothing I can do about this, I read more online and sure enough temps for this sucker are high, most people can't run the torture test without hitting the limiter so at least I got away from that.
That being said, playing ANY game so far doesn't spin up the fans at all, PC is ultra quiet and playing Witcher 3 or Middle Earth barely uses the cpu anyway so maybe that's why, like 9% usage at 1440p. Probably a cpu intensive game would go up a bit, but I doubt I'll ever use the cpu like P95 does, although I'll have to test handbreak encoding, and if that makes the cpu go 93C I'll have to get some other solution, as that is part of what I do.
