Guys, let me explain my dilemma.. So I got everything installed (I'll update my sig today so that you can see my new rig, x570 with 3600x), but temps seem high to me. They are hitting 40C in bios, or close, and in Windows with minimal use it's 45C, with mild use it jumps around but sticks around 45C, then I did a blend Prime95 test and it went to 75C, but then I did a torture test in Prime95, cpu only, and INSTANTLY it hit 96C, in less than a second, and my computer sounded like a vacuum. I only did that cuz I figured I need to test the temps before I starts gaming, and now I'm afraid to even open the game!! I installed the stock cooler correctly, I may re-apply the paste but even that I've done many times in the past. My FX8150 would hit 60C on P95 torture test max with the 212 evo cooler (is that cooler compatible with my mobo?).
So, I bought 4x140mm Corsair fans, real nice, but could only use 3 as the top of the case can't take 2x140mm if I want to put cables for CPU power through the top, they are in the way (I only run one on top), so now I have 2x140mm in the front intake, 1x140mm on top and 1x120mm back with 1x140mm outside not doing anything.
So, either I can buy a cooler that can take a 140mm fan (which I don't think is possible), but I also thought, do water coolers (rads) come with fans? Or could I get a rad and pump only and use the two 140mm front fans and mount them on the rad and then use that for my cpu and case intake. I want good cooling, and this seems to be the best solution, although judging by the huge temps I don't even know if that's possible.
So, any ideas on the latter (I will check out the coolers you guys mentioned for sure, but now I'm leaning towards a 280mm rad for the front of my case with the 2 Corsair 140mm fans.
EDIT: I can also use 2x120mm on my cpu, no problem, but do I have enough mobo pins? I think I have only two more available, one says WPUMP and the other AIOWATER, all the ones used for fans are taken, 4x system fans and 1xcpu (I have 1xcpu optional still available I think, or maybe I'm using it already). Can I plug a fan into one of the water connectors on the mobo?
EDIT 2: My plan is to upgrade to the best cpu that is on offer for the x570 in the near future, so water cooling is definitely on the table for futureproof, I just can't handle the CPU hitting limits, but I also can't handle buying $40 fans just to not use them, so now that I have 2x140mm I need to figure out how to use them if I do go watercooled. Do rads support push/pull so that I would have 4 fans? Any AIO? Then I have to figure out how to power them. Jeez, I wish I could just get a water block and rad and that'st hat.
