The air units which are cheaper are pretty close to that, easier to install and won't ever leak on your gear. If I were to get wc I'd go for the Cm Eisberg kits for 110usd at the egg. (or so they were priced at last I looked)
Definitely, excellent cooler for the price
http://www.overclock.net/t/1423039/cooler-master-eisberg-solo-120l-240l-owners-club
My configuration (212 Evo + variable speed 120mm Delta case fan) just fits within your $70 budget and will even handle a 6 core with ease. (Upgrading the fan on the 212 Evo pushes it over your budget, but you won't need that for your CPU.) You can also get great results with a somewhat lower end case fan.
No it doesn't...many reviews suck. If you test with a not big enough heat source you'll get strange results, same with measuring ambient temps incorrectly.
Trust me, that True Spirit I posted is the best price/perf heatsink you can find new. That or the new noctua single tower equipped with a 140mm fan.
Or used gear like others mentioned here. Also, the cm hyper 212 is really noisy compared to these other heatsinks and it needs it to be since the fin stack isn't big nor wide enough for low speed fans.
AIO solutions are not better than high end air, with all the issues that can come with it.
If you want watercooling, go custom loop.
Could you give us a link to website there in Malaysia you would buy from? Than we can see what coolers are available and their prices.
First link
NH-U12S RM 245.00 + 9.60
NH-D14 RM 269.00 + 12.00
NH-D14 is much better.
2nd link
Hyper 212 X RM 125.00 + 8-13.00 Good low priced cooler
3rd link
Venomous X RM 299.00
IFX-14 : RM 309.00
Way over priced. IFX-14 was released in 2007. It is the original design that became Silver Arrow in 2009-2010. Not even available anymore in most places.
4th link
Megahalems RM 220.00 + fans
Great cooler but add the cost of fans and it's not cheap.
My recommendation
Hyper 212 X
Half the price of next closest contender (NH-U12S) with very similar performance.
http://dvtests.com/?p=12794
The only way I will leave air is if I am given a good H2O system that cools everything. GPU, CPU, mobo, RAM. I don't need it, but it would sure look nice in my new Phanteks Enthoo Primo when it arrives.
Big coolers do not break motherboards. Not unless you push your case off of your desk.
Megahalem is not small. With 1x 140mm fan it's 141x100x158.7mm w/2x it's 141x126x158.7mm. Megahalems w/ Silverstone FM123 is 14c cooler than 212. A14 FLX will perform as good or better.
http://www.hardwaresecrets.com/article/Cooler-Master-Hyper-212-Plus-CPU-Cooler-Review/956/7
Your NH-A14 FLX is a good fan. I use lots of Thermalright TY-14x series fans which are very nice fans with a very good reputation.
NH-A14 FLX & TY-140 performance on Megahalems:
TY-140 @1266rpm = 23dBA & 45.5c
A14 Flex @1243rpm=29.5dBA & 46c
http://www.vortez.net/articles_pages/120mm_and_140mm_fan_comparison,18.html
212X is best value.
Megahalems is better cooling and quieter, but RM 95.00 more money.
I agree with the cooler master 212+.
As far as running a FX processor at stock the CM 212+ it will do this fine. Just make sure the MoBo you get can handle the higher wattage or your socket temp will be higher than you want it.
You said the key words a few posts above Ghost Nova, you won't be overclocking, just looking for silence and better temps.
Get the 212 EVO and call it a day.
The stock fan is on the weak side (but very easy to upgrade) and case ventilation counts a lot. It easily keeps my 3930k in the low 60s at full load.Omg....some tell me the Hyper212 is good , now some tells me it sucks...
