Min Vcore of 1.36V and Max Vcore of 1.44V will not really hurt your system.
(I was refering to 3.25 as max which obviously is wrong and if you look in detail +3v min is shown 1.36v, +5v is 2.28v min and RAM volt max is shown 3.2. So I asked him to use other monitoring softwares, who knows what is exact volts or temps are????) You would need voltages like that to get to 4.2Ghz or higher anyway, BUT temps are too too too dang high.
What I do not think is good and why I told you to manually drop Vcore to about 1.3Volts is that your CPU Temp of ~77c and your CPU Core Temps of 66c at 3.8Ghz with the current voltages is too too too much HEAT.
I would not continue to run that hot. I would do something if nothing but try and lower the voltage to the cpu or quit running the cpu that fast. And we know that your stuff is running way too hot. So quit running Prime 95 until you get the cpu cooler. No sense in stressing your parts for no reward. Simple. You need much better cpu cooling.
