- Dec 19, 2012
Ditch the single 8GB stick and run the 2x4GB in dual channel. .
EDIT: Does AMD have XMP? If not set the speed, timings, and voltage manually.
I'm with E_D on this one. Ditch th Adata unless you absolutely need the extra ram using the two in Dual channel will give much better performance and would be alot more stable. This could have been causing your PC to freeze. It also could be your board heating up that was causing the freeze.
AFAIK E_D I haven't seen an XMP on any of my boards. AMD developed their own system called AMP ( AMD memory profiles) but I never see it either.
