- Jan 12, 2012
I have one of your old ones C/D and you're not getting it back
I wouldn't say that at all - mine is probably just overvolted more - I don't really trust Gigabyte to monitor voltages correctly on their AM3 boards anymore. The gigabyte 990FXA-UD5 I'm using has not just a terrible bios, it has terribly coarse voltage adjustment. 0.025v increments suck - jumping from say 1.550 to 1.575 really is exponential heat.your cpu is a good bit better than mine
Ahh well that makes sense then. Real cpus for real work.
That's a good guideline if you want your chip to live, yesI usually stay at or below 1.45ish with my water cooling.
Thank you for sharing sir.it looks like I have reached the end of the line with this rig
Yeah keep it cool and pump the volts to it. If you're interested in OC that chip you'll get more attention if you start your own thread. There's also a good guide at the bottom of my sig for overclocking PII/Thubans
Oh and welcome to OCF Dopelovinghippy
