- Sep 9, 2003
- New Jersey
Okay, I built a new rig today with my notorious MSI K8N Neo2. Here are the particulars.
Opteron 144 cooled with XP90 and Panaflo Med Speed 92mm
2x512 PQI Turbo PC 4000 TCCD
160gig WD SATA hard drive
Enermax EG465P VE
2 Optical drives and a floppy
Okay, every piece of gear with the exception of the Opti is used and in good working order. The hard drive was in my NF2 rig so, I figure I can get away with just a Windows repair install. Everything goes great. In fact, windows runs fine without the repair, so I figure I'll do that tomorrow and in the meantime I test drive it. I know the board and the ram, so there is no question of what they can do. The only variable is the CPU. I take it all the way up to 9x300 and run about 20 minutes of Prime and Super Pi 16m. Everything is fine. I back it down to 9x250 with my ram running at 1:1 at stock speed and settings. It's chugging along fine, when I decide to run some Sandra test. I check out bandwidth and then just run one of those simple system reports, not a benchmark. The system freezes. I go to reboot and I get a hard drive failure notification! I run some quick WD diagnostics and of course it passes. I decide to to a Windows repair install and it finds the drive sans it's old partitioned and says the is unformatted? WTF!!! How could this happen? Is the hard drive failing? What could cause everything to get wiped out in an instant? Any insight on this would be helpful. Thanks.
Enermax EG465P VE
