Correct. That is stock for the RAM sticks. But you're overclocking the IMC (integrated memory controller) on the CPU.at stock with xmp off ram goes at 2166, and these are 2400mhz rams
I understand. What you're not getting is that it IS overclocking the memory controller on the CPU.the stock of these rams is 2400mhz, not 2166
air coolerYou WILL NOT see and increase going to 2400mhz from 2133. You stated that you hit 78c @4.5 with 1.35v BUT the screenshot shows 1.375 requirement for 100% load > are you using a AIR cooler or a AIO and what is it (air)/what size(aio) so we will know the cooling capabilities. In the BIOS set 4.6 and then rerun the stress test this SHOULD put you @ ~ 82c. Anything more that this will cause the CPU to throttle/down speed until the high temp is reduced.
* You have to remember for every + in speed = more power required = more heat generated.
* Increasing the speed of the memory = more power required by the IMC = more heat is generated which is then TAKEN from the MAX speed the CPU CORE can do.
* The NB or Ring Ratio (set to auto) requires xx volts SO increasing the speed = more power required = more heat is generated which is then taken from the max speed of the cpu core.
^^ WELCOME TO OVERCLOCKING ^^ and the NEVER ENDING pursuit on better COOLING for FASTER SPEEDS.
^ The Intel Specification lists the speed of the i5-6600k at 3.5GHz and Turbo to 3.9GHz. From what you have listed 4.5/4.6GHz is the best you are able to achieve with this CPU.
actually i have set to 1.35, but cpuz during a stress test show 1.376vWith an air cooler - your max is 4.5GHz. This is because of the heat/temp of 78c. I do not know if the stress test you used runs AVX as this requires more power. If you have the cpu voltage set to auto in the BIOS = it needs 1.35v to boot and run BASIC programs. It needs 1.375v to run programs that require 100% usage.
It is not strange. Software readings are notorious for being inaccurate. Confirm through another program like Coretemp or Hwinfo. Did you use LLC? That can increase load voltage too...actually i have set to 1.35, but cpuz during a stress test show 1.376v
for this i say that is strange, max should be 1.35 also in cpuz
So....... how'd your testing go?
for now seem all ok, if i will have freeze or crashes i will wrote again hereIt is not strange. Software readings are notorious for being inaccurate. Confirm through another program like Coretemp or Hwinfo. Did you use LLC? That can increase load voltage too...
No clue. Since you changed multiple things and haven't tested at stock yet, it's tough to tell. It could be your OS or storage going bad, even.could be a ram issue or a cpu issue?
ok i'll try first the 2133 on ram and see if is the ramNo clue. Since you changed multiple things and haven't tested at stock yet, it's tough to tell. It could be your OS or storage going bad, even.
So, again.... reset EVERYTHING to stock. That means leave the memory at 2133 and the CPU voltage/multiplier on AUTO. Run your PC.
If it happens again, we know it wasn't the overclock settings and need to test more.
do you know if the blue screen of death is always related to low vcore when doing overclock?No clue. Since you changed multiple things and haven't tested at stock yet, it's tough to tell. It could be your OS or storage going bad, even.
Depends on what the message is from the BSOD.do you know if the blue screen of death is always related to low vcore when doing overclock?
i had another hard freeze with memory at 2133mhz, so is not xmpDepends on what the message is from the BSOD.
Is it? You(we) have no idea. You can play with voltage, or put everything back to stock to be sure.is the overclock on cpu
Today after 14 days with no freeze, i had a freeze with unpacking a game, i remember that the previous freeze was when unpacking a update on a gameIs it? You(we) have no idea. You can play with voltage, or put everything back to stock to be sure.
