As far as 38mm fans go, do you guys think it'd be worthwhile to mount my 2 Scythe Ultra Kaze 2000s on my Xigmatek Gaia, use my Yate Loon mediums, or go with the fan that comes with the heatsink?
Turns out the Ultra Kazes didn't fit over my memory heatspreaders, so I'm rocking the single Xigmatek fan for a while.
Your lucky, my ram doesnt fit in the first 3 slots with a 25mm fan, nevermind a 38mmI'm going to try out moving the memory to the next slots over (slots 2 and 4) and see if the fans fit when I get home.
And this, dear children, is why Daddy says to always buy low profile RAM, no matter what the salesmen might say.
The G.Skill Sniper memory I bought has fairly small heat spreaders, I didn't think they'd get in the way. Sadly...
Do you think a fan will fit above the Vengance RAM with heatsink removed?
I'm tempted to get some 3000rpm 38mm fans for the CPU but there is absolutely no room right now with the heatsinks on.
And does the memory actually need a heatsink?
