Im trying something new. Ill be running two loops. I wanna know how i should install my L/C System. I purchased one CPU Block. One N/S Bridge. Two VGA Blocks. (Debating on the mosfet) Two Reservoirs. Two Radiators. Two Pumps. The links are down below to see the pictures. As for the Rig, everything is at stock settings but will be Overclock in the future. I want one pump to run like the VGA and the other pump to run the CPU, N/S Bridge and maybe the Mosfet. (If i decide to get it) Is that the best way or should i route it a different way. Thanks for your help....
CPU EK-Supreme FULL COPPER EDITION- Highest Performance CPU Water Block
http://www.performance-pcs.com/cata...cts_id=26026:56bbe41e820e2573f4f11cf746d99f01
N/S BRIDGE Koolance MB-EVX58 (EVGA X58 SLI)
http://www.koolance.com/water-cooling/product_info.php?product_id=804
GPU'S (2) Koolance VID-NX295S (GeForce GTX 295, single board)
http://www.koolance.com/water-cooling/product_info.php?product_id=857
PUMPS (2) Performance-PCs Über 655 Fully Modded (D5) 12 VDC Water Pump
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=201&products_id=24737
RES (2) XSPC Bay Reservoir 5.25
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=318&products_id=22013
RAD (2) XSPC RX240 Extreme Performance Radiator
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=200&products_id=25388
TUBING Feser Tube Active UV Hose - 1/2" ID (3/4"OD) Anti-Kink Tubing - Clear / UV Blue
http://www.frozencpu.com/products/7...bing_-_Clear_UV_Blue.html?tl=g30c99s172#blank
This is what its going on..
CASE Lian Li PC-888 Blue Anodized Aluminum
MOBO EVGA X58 3-Way SLI Core i7 Motherboard with Tri-Channel DDR3-
CPU Intel Core i7 920 2.66GHz 8M L3 Cache 4.8GT/sec QPI Hyper-Threading Turbo Boost LGA1366 Processor
MEMORY Corsair Dominator 6 GB 3 x 2 GB PC3-14400 1800MHz DDR3 Core i7
HHD (4) Western Digital VelociRaptor 150 GB Bulk/OEM Hard Drive 2.5 Inch, 16 MB Cache, 10,000 RPM
VGA (2) EVGA Geforce GTX 295 CO-OP Superclocked
PSU PC Power & CoolingTurbo Cool 1200W ESA
