so, you actually prime then so you need prime stability? Does your system freeze for what you do/how you use your pc?I used Realbench stress test and lowered my core voltage - 0.020v from the original +0.075v and it passed, however prime95 failed in round off checking. So much for Realbench for me.
I use my PC for everything gaming, Encoding video streaming, web surfing, E mail, shopping, it is on six hours a day. I'm having a data corruption problem, I'm trying different memory now.so, you actually prime then so you need prime stability? Does your system freeze for what you do/how you use your pc?
Personally, thats how i choose my program. I dont judge its effectiveness based off another application.
running x 45 @ 1.37 V, didnt won the lottery this time @ tempas max 75 degrees. Is this good or should i try x46 ?
If you're running 4.5ghz @1.37v i think the best you could hope for is 4.6ghz @1.41v/1.42v if you can get it stable
