- Nov 10, 2012
- Ankeny Iowa
You have come over to the darkside LoL
Sin get a fan on the backside of the motherboard so you can get the Socket temps down.
I would put a fan on the vrm section or behind the mb and that should get you some more headroom
Even if the side panel behind it doesn't have a cut out it still helps move that hot air away.not really anyplace I can put one behind the mobo My socket cut out is big enough for sure but wont get any airflow with case closed.
just cut up a cardboard box and make a simple guide to get the air to the vrm.
a little black paint makes it look a little better.
The rear fan should do the trick as its close to the area and will look better
I can't find away for rear of the mb either
