Passed 20 minutes of blend at 1.385 vcore in bios and CPU at 4.044 ghz.
Wow! Very nice dude!
Looks like I've got some work to do tomorrow - I'd love to run at 4.0 with a lower vcore than what I have now.
Are you going to do a longer blend run? What was your highest reported temp?
ok i enabled cpu llc and ran prime blend for 4 hours....54c CPU, 43c CORE, 29c MB..also upped DRAM to 1.5125....as you can see Vcore was at 1.57 the whole time.....too much? i will be getting a new cooler so it should drop the temps a bit as well.....
I would not feel comfortable with vcore that high. Have you tried what I tried with using a combination of the multiplier and the bus to overclock? It seems to be allowing me to get by with less voltage than when I was only using the multiplier. Of course, there are more variables to interact with when you use the bus.
Same settings as in post #20 but with vcore lowered to 1.365 in bios. Pic of HWMonitor shows how much supplement to that was made by LLC. Love those low temps. Until later. Sack time.
Maybe if you were running over 1.6v. At 1.5v, no.Well, I just discovered that my system is no longer stable with the 960T at 4.1. Core 3 started dropping out. Degradation over time? Anyway, I lowered it to 4.0 and upped the vcore to 1.5. I'll do some Prime95 longer testing tomorrow but it is at least stable for running Prime for a short test.
You can't go wrong with either the Noctua D14 or the H100. My only hesitation with the H100 (or any water system) is the possibility of leaks that potentially could ruin your whole system. Probably a remote chance but we have had some reports on the forum of the water block/pump coming apart or the pump dying. With air cooling there isn't much that can go wrong.
Ripsaw, I would point out to you that before I started using a combo of fsb and multiplier I needed 1.5 vcore to be stable at 4.0 ghz. Now, using a combo of the two I am needing less than 1.45 to be stable, even taking into account the LLC offset. And my idle vcore is now under 1.4.
yeah, tweak the CPUNB voltage some or maybe even the frequency and the HTLink frequency as well but not the HT Link voltage - it doesn't like to be messed with. To do this you'll probably need manipulate the fsb some.
I'm testing out my CPU now with two unlocked cores, seeing how far I can get it as a six core. I have already realized I need more CPU voltage and it really generates considerably more heat with the two extra cores.
Well I got it to boot, but it was not stable enough to run prime at 4 ghz+. I probably could have added more voltage, but with llc it was going to 1.47 under load - going higher isn't worth the extra 100 mhz to me.
Oh well, 3.9 on 6 cores is alright by me.
Can I ask what you guys have your ram timing set to? I just have it manually set to the ram default timings at the moment.
