- Mar 4, 2012
- South Vancouver Island B.C.
- Thread Starter
- #41
nice....mine wont unlock stable at stock settings, and they should....so i think theres at least 1 bad one......61c is pretty high though isnt it?
Keep in mind that is his socket temp. The core temp is about 9 or more degrees cooler. Does your mobo let you select which cores to enable?
I have been running my 960t unlocked and over clocked with 16 gigs of G Skill 9 9 9 24 timing 1t, 2400 fsb and HTT my voltage is set to 1.375. I have been running stable for over 3 weeks. I am using a 16.5 multiplier, my memory speed set to 1600, HTT multiplier of 12, memory voltage 1.50. This is a Gigabyte board.....
FSB of 2400? Did you mean 240?
Have you run Prime95 blend for at least a couple of hours to confirm the stability of these settings?
With Handbrake I rendered a 1 hr. mpg video recording into mpg4 in a little over 5 minutes with my 960T on 5 cores and 4 ghz. These Thubans really shine in that kind of task. Handbrake is one of the few real world aps I know of that is truly multit-hreaded and can take advantage of a CPU with lots of physical cores. I was watching the CPU Meter gadget while it was rendering and all of the cores were being worked very close to 100%.
