- Jan 9, 2005
Why would you be done with the best/fastest/most reliable exchange?
You can trade and make $$$ all day there
I think he is saying he is done with being a fee holder.
I'm going to sell mine if they go up at all.
Woke up this morning to find the computer totally shut down. No time to look at it before work, hopefully I'll get a chance to figure it out tonight.
Did they get the max wallet working? Is there another way to store it off of an exchange? With the way max is going, it'll be awhile, if ever, before it is worth much again.
I downloaded the wallet zip file from the link above. It has both a command line and a QT (gui) wallet. Is there a way to limit the bandwidth used by the QT wallets? They use so much bandwidth it slows my miner speed down by 50% when syncing.
I'm mining Max again. 10.5 so far over the past 19 hours or so.
Yours must have caught the same bug mine did. Started it mining Litecoin yesterday before I went to work... 30 minutes later it was offline. Came back later to find that the 270X had gone sick and CGMiner had crashed.
Makes me wonder if I really should keep the bulk of my hashing power in just one computer. Thinking perhaps I should move the 270 into one of the office rigs and retire my HD7770. It's not like that card is a real barn burner when it comes to mining. Then again, it's the only one that's found me a block anywhere, so it's kind of a good luck charm. Doesn't hurt that I can leave it mining for weeks and not have to touch it again.
and boom, its already crashed once since i got home and started everything back up...
i wonder why it has started to go screwy all the sudden...
i guess i will try it out one card at a time, see if its one of the cards thats causing errors, or if maybe it is a problem somewhere else in this old system.
Did cgminer crash or the whole pc?
if it's cgminer, just shove thins into your .bat:
:loop
cgminer.exe -all your standard stuff like TC and -I...
goto loop
That will simply relaunch the miner every time till you click the "x" to kill the whole shabang.
Works for me, my 270x is still crashing once in a while, and I just watched cgminer literally close without warning today
Anyone mining helixcoin?
Maxcoin/pokemon cross? Is pokemon still that popular that you would reference it for your coin?
