- Apr 26, 2012
- New York, USA
I'm not sure, but I think stock voltage is CPU specific. Having said that, your VCore @ just over 1.3, is low indeed. Temps permitted, you could probably push upward of 1.4 and get a pretty decent overclock on it. If 44C is socket temp (reading from post #18), then your core temps are probably closer to the mid to high 30s if my estimations are correct. Is there a way to verify that under Linux?
If that is indeed the case, you have plenty of room for a modest VCore bump. From there, it's just raise the multiplier, run Prime, rinse and repeat until no longer stable.
