g0dM@n said:They make single-sided 512s????
HeXenViRii said:Could I run dual channel with 4 of the same sticks ?
... with a newcastle ?
g0dM@n said:Socket 754 doesn't do DC from what I know. As long as you have a s939 then you can do DC, even with 4 equal sticks.
Zebbo said:Socket 754, huh? I thought all the K8N Neo2 are Socket 939
He can get the dual channel with 4 sticks, yes. But 2T command time is overkill
Zebbo said:Q: I have (example) KHX3000 BH-5 sticks and I need to have a 1:1 divider, how can I do this?
A: There's problem (according on Asus report) on AMD64's integrated memory controller, so ram sticks without 3200 SPD information this cannot be done through BIOS, however, with A64Tweaker it's possible to "force" 1:1 divider so you can use your FSB and memory with synchronized speed. Run A64Tweaker, and select MEMCLK Frequency: 200 and hit 'Set'. If you're facing instability or your PC freezes up after you have done this, reset your PC and when you're back on the Windows, run A64 Tweaker and select first Refresh Rate (Tref): 200MHz 15.6us and then select MEMCLK Frequency: 200 and press 'Set'. Now you're running your FSB / MEM with synchronized speed.
Yes, that's correct. If it doesn't work at the very worst the system will freeze and you have to reboot.RAMMAN said:refresh rate (tref) is currently set to 166mhz 1.39us in a64 tweaker.do i have to change that to 200mhz 15.6us at the same time as setting the memclk freq from 166mhz to 200mhz in order to force 1:1 ratio without instability?
I have heard that as well but many people use them without a problem.[-NM-] KB said:Question, I thought that I read somewhere that the Nvidia Gart drivers were not recommended if you were using XP sp2? Anbody else heard anything about issues with the gart drivers and SP2?
The GART drivers drive your Gart, silly.g0dM@n said:What the heck do the Gart Drivers do anyways?
rseven said:Yes, that's correct. If it doesn't work at the very worst the system will freeze and you have to reboot.
If it was a rush job you should have told me. I'd have answered it next month.g0dM@n said:Thanks for answering me 2 months and 2 days later.
