- Sep 25, 2015
I figured I would post my experience here in case somebody has the same issue that I did...
Last night I was playing around with various memory overclock settings on my motherboard. Lucky me, I found a combination that caused my motherboard to get into an endless reboot cycle...would not even post into bios.
Fearing that I had bricked my motherboard bios, I decided to try the following:
1. Powered off the computer
2. I hit the "OC Genie" button on the motherboard (which was a PIA as I had to remove my 2nd graphics card as it covers up these buttons)
3. Power on computer...it started the post process.
4. When I got into BIOS, I turned off the "OC Genie" through the BIOS option
5. I loaded a stable overclock setting
6. Saved and rebooted...the motherboard posted
7. Got into BIOS and turned off computer
8. Turned off the "OC Genie" button on the motherboard, reinstalled the graphics card, rebooted
9. Went into BIOS and reloaded my stable overclock setting
Phew...didn't brick the BIOS.
Not sure if this will work for other MSI motherboards, but it kept me from having to do anything fancy.
I hope this helps someone!
