- Jan 16, 2002
- Thread Starter
- #21
ed.howell said:What kind of CNC are you going to be using? If it's a good one like a Makino or another high speed CNC you will be able to cut that in maybe an hour or two and you won't have to worry about breaking those towers.
What type of software are you using to cut that? I am a Plastic Injection Prototype Moldmaker so I am familiar with stuff like this. If you can ramp your cutter to cut those towers. Don't ruff them out cut right to finish. I cut stuff similar to this all the time. We use Fadal CNC's with Siemens high speed controllers. They are descent but we are looking into some Makino's.
Listen to me I am sure that if you can draw that up then you know how to machine it . I am just trying to help.
Good Luck,
Ed
Ya know, in all the time I've worked there, I never bothered to check the brand name of the cnc, or the software it uses? I guess I'm just dumbfounded by the great work it does, but I have seen many very intricate peices come from it, so I'd say its a pretty high quality machine. I would immagine it used Siemens controllers as well as almost all the other machinery does and the machines we sell use them.
Thanks for the tips.
