- Aug 10, 2010
- Sunshine State
Well... it's time to buy the hold-me-over-until-my-gaming-rig-gets-built unit now that my every day PC got fried.
I've got it down to 2 options....
Option 1 -> Tigerdirect barebones kit @ $299.99 Here
* MSI 785GM-P45 Motherboard
* AMD ADX635WFK42GI Athlon II X4 635 Quad Core Processor
* MSI R5450-MD1G ATI Radeon HD 5450 Video Card
* Cooler Master RC-310-RWN1-GP Elite 310 Mid-Tower Case
* 350 Watts Power Supply
RAM is not included, so I found this one
G.Skill Model F3-10666CL9D-2GBNQ @ 49.99 (Newegg)
That brings the total to $349.99 + S&H ~= $365 delivered.
Pros
- I get a 1GB 5450 -> Not the best card, but more than enough for light gaming.
- Comes pre assembled so less work for me.
Cons
- PSU seems to be on the low/cheap side. Afraid it may cause damage in the long run.
- Comes pre assembled so I don't get to put it together myself.
- Only 2 GB of 1333 RAM
Option 2 -> Newegg hand-picked parts @ 346.99
* SILVERSTONE PS05-B --> Link
* AMD Athlon II X4 620 Propus 2.6GHz --> Link
* ASUS M4A785TD-M EVO AM3 --> Link
* G.Skill Ripjaws Model F3-12800CL7D-4GBRM 2x2GB 1600 + Antec NEO ECO 520C 520W Combo deal. --> Link
This one as it is comes out to $346.99 + S&H ~= 364.99
This one doesn't include a GPU. The MoBo has on-board video that should be more than enough for now.
Pros
- I get 4GB of faster RAM.
- I get a better MoBo
- I get a better PSU? Not sure if the ANTEC will be any better than the other one.
Cons
- No GPU
- Slower clock Athlon II x4. The one in option 1 is 2.9MHz vs 2.6MHz in option 2.
Now for the questions:
I'm in the process of pricing out and about to start buying components for my main rig. That one will be in the neighborhood of about U$2.5K not including waterworks. I'm not made of money, so needless to say that any money I spend on the replacement PC will take away from my main rig's budget (or at least delay the completion a bit).
And with that in mind; let's say I was to up the budget an extra $50, so we could have $400 + S&H.
What would you recommend?
* Upgrade the RAM in Option 1 and be done with it.
* Get the best GPU that you can with the $50 bucks and be done with it.
I have the 3 HDDs from the dead PC, those will be more than enough for now.
I also have a GeForce 6800 GS and a SoundBlaster Audigy 2zs that survived the death of my old PC.
The GPU in option 1 is much better than the 6800; however, I do like the parts in option 2 better and would like to know if the 6800 would be compatible with the EVO MoBo from option 2. I'm thinking NOT, but one can hope.
* Is the 6800 compatible with the EVO MoBo?
And then there is the audio. The Audigy is a decent low level sound card, but I'm thinking the on-board audio on the MoBo would be better.
* Which do you figure is a better audio option?
Cheers
Sebas
Pros
Cons
Pros
Cons
- No GPU
Cheers
Sebas
