- Dec 27, 2008
Looks to be a micro atx..
The HP specs say mid-Tower but I don't know. It's a funny looking mid-tower.
No one else noticed he has 2.2V core voltage? The F?
Vexus can you give us a picture of your bios under that "Power" tab on top?
2.2V cpu voltage is going to kill your chip very soon! Max safe voltage for that cpu is around 1.4-1.45 maybe even 1.5 with good cooling.
Hopefully you have some settings under that Power tab in bios to change this.
If you want to overclock, buy a new mother board and PSU like suggested.
Why would computer OEMs add overclocking support? These are aimed at Average Joes. Average Joes compete with potatoes in Overclocking Knowledge (no offense intended, just to illustrate). Imagine your Average Joe decided to tinker with the BIOS and finds a "Core Voltage" setting, and he uses icebob's logic of moar volts moar speed. He bumps the voltage to the sky, somewhere around 2.6v and successfully fries that chip. This guy would get veery angry at the company because his computer is now a mere paperweight. And the company's reputation will go to the floor. It's easier, and safer, to give them a stripped to the bone BIOS that just lets you set the RTC time and boot devices, since that's what an Avg. Joe will do.Those factory built PCs don't allow Overclocking. Those factory PC mobo bios's are usually stripped to the bone. Even if you did overclock the chipset might get very unhappy.
Foxcon + HP & Overlocking = Big epic fail.
Buy another mainboard, ow wait. That doesn't fit in the HP case, Then also buy a new case, **** the PSU doesn't fit! Ow crap it's HP.
I'm not sure of my budget just yet, I have to go to the bank tomorrow, close a bank account, then open up another one somewhere else...
lets just say my budget is that i want something cheap, but good, atm...
Where do you live? Cheap and good, very hard to find, but possible.
yea, i caught the 2.2 cpu voltage, much to high.
I get the feeling he needs a new $50.00 case and the mobo trents has linked for a starter.
