Ok, so I've gotten everthing set up, but for some reason, I've been getting more blue screens in 2 weeks than i have had in the past year.
Here's one (idk what to call this, but its like a dump analysis, i guess?)
Microsoft (R) Windows Debugger Version 6.12.0002.633 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\092412-34070-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: SRV*C:\Symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Built by: 7601.17835.amd64fre.win7sp1_gdr.120503-2030
Machine Name:
Kernel base = 0xfffff800`02a03000 PsLoadedModuleList = 0xfffff800`02c47670
Debug session time: Mon Sep 24 10:26:09.300 2012 (UTC - 7:00)
System Uptime: 0 days 19:47:21.502
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 124, {0, fffffa8008084028, b669c000, 135}
Probably caused by : hardware
Followup: MachineOwner
2: kd> !analyze -v
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
WHEA_ERROR_RECORD structure that describes the error conditon.
Arguments:
Arg1: 0000000000000000, Machine Check Exception
Arg2: fffffa8008084028, Address of the WHEA_ERROR_RECORD structure.
Arg3: 00000000b669c000, High order 32-bits of the MCi_STATUS value.
Arg4: 0000000000000135, Low order 32-bits of the MCi_STATUS value.
Debugging Details:
BUGCHECK_STR: 0x124_AuthenticAMD
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
PROCESS_NAME: chrome.exe
CURRENT_IRQL: f
STACK_TEXT:
fffff880`02f6ca88 fffff800`02ffda3b : 00000000`00000124 00000000`00000000 fffffa80`08084028 00000000`b669c000 : nt!KeBugCheckEx
fffff880`02f6ca90 fffff800`02b8fb03 : 00000000`00000001 fffffa80`08085d30 00000000`00000000 fffffa80`08085d80 : hal!HalBugCheckSystem+0x1e3
fffff880`02f6cad0 fffff800`02ffd700 : 00000000`00000728 fffffa80`08085d30 fffff880`02f6ce30 00000000`0269a000 : nt!WheaReportHwError+0x263
fffff880`02f6cb30 fffff800`02ffd052 : fffffa80`08085d30 fffff880`02f6ce30 fffffa80`08085d30 00000000`00000000 : hal!HalpMcaReportError+0x4c
fffff880`02f6cc80 fffff800`02ff0e8f : 00000000`0299e270 00000000`00000001 fffff880`02f6ceb0 00000000`00000000 : hal!HalpMceHandler+0x9e
fffff880`02f6ccc0 fffff800`02a80aac : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : hal!HalHandleMcheck+0x47
fffff880`02f6ccf0 fffff800`02a80913 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxMcheckAbort+0x6c
fffff880`02f6ce30 00000000`5b4193dd : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiMcheckAbort+0x153
00000000`0299e190 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x5b4193dd
STACK_COMMAND: kb
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: hardware
IMAGE_NAME: hardware
DEBUG_FLR_IMAGE_TIMESTAMP: 0
FAILURE_BUCKET_ID: X64_0x124_AuthenticAMD_PROCESSOR_CACHE
And here's another one
Loading Dump File [C:\Windows\Minidump\092312-8720-01.dmp]
Machine Name:
Debug session time: Sun Sep 23 14:38:51.496 2012 (UTC - 7:00)
System Uptime: 0 days 0:00:03.698
Mini Kernel Dump does not contain unloaded driver list
BugCheck 124, {0, fffffa800816b748, 0, 0}
1: kd> !analyze -v
Arguments:
Arg2: fffffa800816b748, Address of the WHEA_ERROR_RECORD structure.
Arg3: 0000000000000000, High order 32-bits of the MCi_STATUS value.
Arg4: 0000000000000000, Low order 32-bits of the MCi_STATUS value.
Debugging Details:
PROCESS_NAME: System
CURRENT_IRQL: 0
STACK_TEXT:
fffff880`031b66f0 fffff800`02cc4ca9 : fffffa80`0816b720 fffffa80`06d4a040 00000000`00000024 00000000`00000000 : nt!WheapCreateLiveTriageDump+0x6c
fffff880`031b6c10 fffff800`02ba5547 : fffffa80`0816b720 fffff800`02c1f2d8 fffffa80`06d4a040 00000000`00000000 : nt!WheapCreateTriageDumpFromPreviousSession+0x49
fffff880`031b6c40 fffff800`02b0c945 : fffff800`02c80ae0 00000000`00000001 fffffa80`07d2ee00 fffffa80`06d4a040 : nt!WheapProcessWorkQueueItem+0x57
fffff880`031b6c80 fffff800`02a8b841 : fffff880`010a0e00 fffff800`02b0c920 fffffa80`06d4a000 00000000`00000000 : nt!WheapWorkQueueWorkerRoutine+0x25
fffff880`031b6cb0 fffff800`02d18e6a : 00000000`00000000 fffffa80`06d4a040 00000000`00000080 fffffa80`06d30b30 : nt!ExpWorkerThread+0x111
fffff880`031b6d40 fffff800`02a72ec6 : fffff880`02f64180 fffffa80`06d4a040 fffff880`02f6efc0 00000000`00000000 : nt!PspSystemThreadStartup+0x5a
fffff880`031b6d80 00000000`00000000 : fffff880`031b7000 fffff880`031b1000 fffff880`03d22740 00000000`00000000 : nt!KxStartSystemThread+0x16
STACK_COMMAND: kb
FAILURE_BUCKET_ID: X64_0x124_AuthenticAMD_PROCESSOR_CACHE_PRV
Any ideas?
I'll get back to you guys when I get back home from school. (about 3 hours or so)
I did reinstall windows when the new motherboard came. I think my drivers are up to date, but I'm not sure. How can I make sure my drivers are up to date?
So what happens if I get errors? What do I do then?
Pics look good but it does not look like you have Cool N Quiet, C1E, C6, TurboCore and anything else that throttles down the cpu, turned OFF. Also need to go into Windows Power Control Settings and set the power mode to "performance" and then open HWMonitor and leave it open on the desktop recording the min/max temps and voltages and then post those type captures. The captures above do not seem to be settings when the cpu was under load or being stressed by P95 Blend mode.
it was not under load. = It is under LOAD that we care about. And HWMonitor running to get the Min/Max of temps and voltages.
Edit: should I turn that stuff on? = NO! DISABLE those. Set windows power manager to 'performance'.
