- Apr 5, 2009
Hey guys im building a new i7 rig this month. And i want to cool the following:
intel i7 965 extreme
the NB and SB on a evga x58 classified
and 2 nvidia gtx295's in SLI
But what really confuses me are the barb sizes, tubing OD and stuff. So i went over to Frozen CPU and checked out some stuff. So could anyone review it or anything and tell me if i have any better options? Money is no problem, im just going for more performance.
Thanks.
Innovatek Eheim HPPS i High Power 12V Water Pump (501280)
* Select Native Intake Fitting: Eheim Intake 1/4" ID FittingEheim Intake 1/4" ID Fitting
Innovatek Screw-In Hose Inlet for the EHEIM 1048 / Innovatek HPPS Water Pump with soft seal and the compression fitting for 8x1 hoses. Warning: Use of fluids other than the Innovatek Protect family is not recommended. Innovatek will not RMA defective products that have used alternative fluids including UV Dyes. Do not use alcohol based clean... ($6.99)
* Select Native Discharge Fitting: Eheim Discharge 1/4" ID FittingEheim Discharge 1/4" ID Fitting
Innovatek Screw-In Hose Outlet for the EHEIM 1046 /HPPS Water Pumps with soft seal for 8x1 hoses. Warning: Use of fluids other than the Innovatek Protect family is not recommended. Innovatek will not RMA defective products that have used alternative fluids including UV Dyes. Do not use alcohol based cleaners on innovatek products. Did you... ($6.99)
* Select Adapter(s) for G1/4" Thread!: Eheim Discharge AdapterEheim Discharge Adapter
This is an adapter that makes the Eheim 1046 & HPPS pumps' discharge opening compatible with a male 1/4" screw-in fitting. Warning: Use of fluids other than the Innovatek Protect family is not recommended. Innovatek will not RMA defective products that have used alternative fluids including UV Dyes. Do not use alcohol based cleaners on innov... ($4.99)
* Select Adapter(s) for G1/4" Thread!: Eheim Intake AdapterEheim Intake Adapter
This is an adapter that allows Innovatek 1/4" fittings to screw into the intake port on the Eheim 1046/1048 & HHPS pumps. Warning: Use of fluids other than the Innovatek Protect family is not recommended. Innovatek will not RMA defective products that have used alternative fluids including UV Dyes. Do not use alcohol based cleaners on innov... ($4.99)
* Select G 1/4" Fittings (Qty. 2): 1/4" ID Koolance Compression Nozzles1/4" ID Koolance Compression Nozzles
The Koolance 1/4" (6mm) ID G1/4 Threaded Nozzles Pair is one pair of rotational 1/4" (6mm) ID G1/4 threaded nozzles for Koolance components with replaceable nozzles. Nickel-plated brass with compression fitting and gasket. ($9.99)
XSPC Passive 250mm Reservoir - BLACK
Danger Den Black Ice GT Stealth 240 X-Flow Radiator - Black
$58.94 $58.94
ex-rad-82
Danger Den Black Ice GT Stealth 120 X-Flow Radiator - Black
* Add A Radbox For External Mounting!: Swiftech MCB-120™ "Radbox" - BlackSwiftech MCB-120™ "Radbox" - Black
The MCB120 revision 2 "Radbox" retains all the functionalities of the orginal but is now made of injection molded plastic and receives several cosmetic enhancements. Mechanically the product is very sturdy thanks to the base plate featuring numerous reinforcement ribs and it fulfils its function to perfection. The MCB120 Rev2 "Radbox" can sup... ($20.95)
PrimoChill PrimoFlex PRO LRT Tubing 1/2"ID 3/4"OD with 1/8" Wall - UV Green
Thanks!
Thanks.
$58.94 $58.94
ex-rad-82
Thanks!
