Look a you CPU-z pics in post #38. The "Memory" tab gives info about your current ram frequency and timings. The SPD tab gives info about the manufacturer's recommended timings and voltages for your ram at various frequencies (See the JEDEC columns). Also keep in mind that CPU-z reports your ram frequency at half of what you would expect to see because it's not reporting the DDR3 transfer rate its reporting the ram bus frequency which is half of what the transfer rate is.
Currently then, your ram is running at 1000 mhz (500x2) when it is rated for 1333 mhz. (666x2) according to the "Maximum Bandwidth" in the SPD tab. But let's check that out because CPU-z sometimes misreports maximum bandwidth for ram, especially Kingston ram. Please supply more info in your Sig about your ram. What is the actual model number of the ram? All you have there now is "4GB DDR3 Kingston ram".
Also, the stock HT Link Speed and the stock CPU/NB speed for the FX chips is 2200 where as the Memory tab of CPU-z shows that the "NB" (that's actually the CPU/NB) to currently be at 2000. The HT Link Speed shows in the CPU-z CPU tab as "Rated FSB" which is always grayed out for the FX CPUs for some reason.
So, go into bios and manually put in the value of 2200 for "HT Link Speed" and "CPU/NB Frequency".
