- Sep 23, 2011
Hello everyone!
I applied to the forum here because I found the most useful info here and I'm hoping you all can help me get a bit further on my OC to
For the last 3 years I ran a P5LD2 Deluxe + D820 2.4 @ 3.34Ghz with a WC setup so I am not new to the OC - test - going further - test - ect. stuff
Ok here is the deal, someone gifted me a Dell something something computer that had been dusted to death So I started pulling the parts and testing them. I found that the E2200 processor was still woking after testing it in my girlfriends pc. So I bought a 2nd hand P5KC build the rig and decided I wanted to push it to the max as I have the tools for it
Oh yeah before i forget there was one problem at 1st, the mainboard wouldn't start with my Spire Rocketeer 650W, it just gave me a blinking mainboard LED. After some research I found out it was not happy with the power it supplied, so i swapped it for a Enermax 500W and it booted without a hitch!
Well now to the OCing, but let me 1st post all the specs so there are no questions about that
ASUS P5KC
Intel E2200
Geforce 460 GTX
OCZ ReaperX 800 4Gb Kit
Enermax 500W PSU
Thermaltake Tribe Watercooler (Modded to dual heatsink)
I know the power is tight but it should be sufficient I guess..
After 3 days of tweaking and testing I got to this:
1st of all I tested how far my memory would go, I used this guide posted on the OCZ site to go to 1066 on the kit in one step did some memtest and all looks nice and stable.
For all the remaining steps I used 1 to 4 hours of Prime95, because 24 hours per step seems a bit much would take me a week to get a bit of results
Also all stable results where archived with all mainboard voltage settings on [Auto] except for the vCore and memory voltage
Ok on to the CPU with divider on x11
I went from FSB 200 to 240 with a 1.35vCore after that I needed to bump the voltage,
on 250 I needed 1.4vCore to get stable,
on 260 I couldn't get it stable even at 1.5vCore, I tried numerous settings for NB,FSB,ect voltages nothing seemed to really help. Even made it worse, on auto it would boot but crash on Prime but raising some voltages just stopped it from booting or gave Windows crashed
So.. I stopped there 11x250=2.75Ghz just a minor overclock in my opinion
Then I decided I should check if it was the FSB needing more power or what ever..
Put the divider back to x6 and with a few steps the FSB was on 400!
Again all voltages on auto only vCore on 1.35, later I tweaked this a bit more and went down to 1.2875 which I feel is minimum for this setting.
I decided to keep this as my 'fallback' because my RAM can now run on 1:1 and it is very stable, just finished a 12hour Prime95 with 0 errors.
Well as this feels kinda 'stock' (CPU @ 2.4Ghz) to me I started trying other multipliers
on 8x i got to 360 FSB with a 1.4 vCore.
But going beyond this I needed to up the FSB and NB voltages to go further,
370 FSB vCore 1.475, FSB 1.4v, NB 1.55v seemed to give the best results but my temps rose from 53c under load to 59c under load! Quite a lot in my opinion.
And I find the voltage increase from the stock FSB 1.2v and NB 1.25v kinda big..
Later I did a 1.5h Prime run and decided I could test out a bit of gaming on this setting but the PC hard crashed after 3hours and wouldn't even let me back into windows.
I do know now the CPU can run at 2.88Ghz easy because that setting did survive a 4 hour prime run.
Ok I decided to go back to my 'stable' one 6x400=2.4Ghz and up the multiplier to x7 this would give me a decent OC for now and I can go back to my gaming addiction
Well it was a no go, its not even posting tried upping FSB and NB but still no boot..
Also upping the FSB over 420 on the x6 multi will stop it from booting and again I cant find the right voltages to get it better..
I am wondering what I am missing here..
There are some voltages that I don't know how to use exactly like CPU Pll and GTL reference but from what i read on other OC results most people never touch these.
To sum up:
Memory is fine can go up to 1066Mhz no problem but
on x11 multi it will go FSB 250 / 2.75Ghz vCore @ 1.4
on x8 multi it will go to FSB 360 / 2.88Ghz vCore @ 1.4
on x6 multi it will go to FSB 400 / 2.4Ghz vCore @ 1.2875
but in all cases if I either up the multi or FSB a bit it just wont get stable! I would prefer to keep the FSB @ 400 so my RAM doesn't run at low speed when I keep my 1:1 on it.
But I would like the multi to go up by 1 then so I am at 2.8Ghz, sounds like a quite decent OC to me.
Hope someone can help me get it done!
Last but not least I'll insert the BIOS settings that are available:
This is my current config:
JumperFree Configuration Settings
AI Overclocking: Manual
CPU Ratio Control: Manual
Ratio CMOS Setting: 6
FSB Strap to Northbridge: 400
FSB Frequency: 400
PCI-E Frequency: 100
DRAM Frequency: 800MHz
DRAM Command Rate: 2T
DRAM Timing Control: Manual
CAS# Latency: 4
RAS# to CAS# Delay: 4
RAS# Precharge: 3
RAS# Activate to Precharge: 10
TWR: Auto
TRFC: Auto
TWTR: Auto
TRRD: Auto
TRTP: Auto
DRAM Static Read Control: Enabled
DRAM Dynamic Write Control: Enabled
Transaction Booster: Enabled
Boost/Relax level Level: 0
CPU Spread Spectrum: Disabled
PCIE Spread Spectrum: Disabled
CPU Voltage: 1.2875v
CPU PLL Voltage: Auto
FSB Termination Voltage: Auto
DRAM Voltage: 2.10v
North Bridge Voltage: Auto
Clock Over-Charging Voltage: Auto
Load-Line Calibration: Enabled
CPU GTL Voltage Reference: Auto
North Bridge GTL Voltage Reference: Auto
Advance CPU Settings
C1E Suppport: Disabled
Max CPUID Value Limit: Disabled
CPU TM Function: Disabled
Execute Disable Bit: Disabled
ASUS P5KC
Intel E2200
Geforce 460 GTX
Enermax 500W PSU
To sum up:
FSB Frequency: 400
CAS# Latency: 4
RAS# Precharge: 3
TWR: Auto
TRFC: Auto
TWTR: Auto
TRRD: Auto
TRTP: Auto
DRAM Voltage: 2.10v
