- Thread Starter
- #201
OK from those shots I would
Disable CPU spread spectrum
Set ram voltage to 1.55v
CPU and CPU_NB LLC to high
CPU and CPU Current capability to 130%
IF you plan on playing with your ram do the same for it's current cap setting.
After you take the LLC off of auto you may find it'll set a different voltag in the OS under load than it does currently, if so you will have to adjust your CPU voltage.
I already altered the RAM timings to match what was listed in the CPU-Z tab. 9-11-9-27-39-1T. I did notice that it showed two different settings. One of them was 9-10-9-27-39-2T. Should I be using one over the other?
