- Jan 10, 2012
sun tzu, that's the way you should mount them then.
My case doesn't have a way of mounting a fan behind the mobo. I can, however, mount two side-mounted fans that wuld push directly down onto the mobo, while the top mounted AIO and rear mounted fans pull air out.
Linkage
Would that suffice?
I also dropped my vCore to 1.365 << BUT your bios screenshot shows CPU voltage at 1.393750V
RGone...
Right. The changes I mentioned in the post were done after taking these pictures.
I have a quick question, I have been looking at my new sabertooth manual & looking at Sun Tzu's pics. I see he has his graphics card in what looks to be PCIex16 slot 2. Is that causing the card to function at something less than x16? Looking at the manual it shows a single card in slot 2 as x4.
What's te difference between having them in 2/4, rather than 1/3?
Shouldn't be any difference. If I recall correctly even the PCB pathing is balanced for all slots. Unless there is some kind of glitch with the design you should be fine using either of the slots.
