No maybe you have n0t yet gotten as high as some others but if you keep hanging around these wild Rodeo Clowns that frequent the "putzen" thread, you will be one of two things. Nuts or faster. Hehehe. No make that three things. The two named already and the other is poorer in pocket book.
I remember when you got here. You have never paniced or throw rocks at yore shett. You just put your nose to the grinding wheel and ground it on out until you have some nice speeds and all.
RGone...ster.
RGone...ster.
I didn't think the Swiftech h220's were available in the US any more? (I'm making assumptions that SunTzu is in the States)
Just so I'm absolutely clear...
Power the computer down
Unplug the power
Switch the jumper cable It's just a small plastic piece the size of a tic tac
Pull the Battery
All good up to here
Leave for at least 30 seconds...
Switch the jumper back
Put the Battery back in
Then plug it in and power it up
Bingo Bango
I would be way more concerned with putting a fan blowing on the VRMs from the front and one blowing on or taking air away from the rear of the cpu socket. Many cases today have a cut-out in the mobo tray where you can rig a fan blowing at or away from the rear of the cpu socket. And when you go watercooling you WILL need to add those two fans to the Sabertooth 990FX R2.0 mobo setup. Moving away from an air cooler sitting on top of the cpu, removes the overflow air that has been trying to keep the VRMs cool for certain.
RGone...
