- Dec 19, 2012
Back up and running. Running P95 now...I'll post results later.
Thanks for the help
So what was the problem??? Hey I've left the HDMI cable out before and tried for 10 minutes before I realized WTF I had done!!
Thanks for the help
Okay. Got it.
If I'm error'ing out in P95 after about 20-25 minutes, is that directly related to the CPU, or can it be CPU_NB related, too?
How high can you safely go Vcore wise? 1.45?
My 8350 will do 2400 NB and HT Link at 1.18 volts. With high FSB then it takes 1.3+ volts to run 220+ without an issue. It's actually quite weird that down low it almost doesn't matter but almost any touch in FSB and it needs more CPU/NB voltage.
Frustration.
I can't get this thing above 4.4 without it failing P95 and/or rising above 62C. When I bump the Vcore up to 1.4, my package temps go higher than my socket temps.
Ugh.
I have absolutely no idea what the voltage was doing. I did notice that the CPU fan kept alternating between 0 RPM and the normal RPM. Sorry...I don't know enough about this stuff to give you strong feedback.
Here's where I sit now. I can probably drop my Vcore slightly to see if I can drop a few degrees. I'm done for the night though. What did you want me to try?
Sun Tzu said:Settings adjusted slightly. I haven't tried lowering the vCore yet. I'm torn between dropping the vCore, or bumping the multiplier. This whole process has been...well...difficult.
