Sjaak... I'm going to attempt it BUT... if I cut the AGP slot and make pieces... it'll be like this:
_________
|________ <--- see the opening? That's where it would be cut.
So one end on each of the pieces I make will be able to slide around. I also have to figure out how to make it snug, so that I don't SCREW anything up while the system is on. We don't want it to be sliding around.
Is there anywhere we can find a ribbon to use? I'm thinking that maybe I can use an IDE cable for the briding of the two slots???
**Edit** Considering there are two sides to these SLI connections on the card, we need to know what is meant by 1:1 connection for the bridge.
1. Are they going to connect GPU side to GPU side, and back to back side... or
2. Is it going to be GPU side to back side, and then back side to GPU side?
I think choice #1, but we need to be sure of this...
