Yes, that is a nice overclock for that cpu. Congrats! How much voltage did you have give the cpu to get there?
Yep - vDIMM & vCore. But that wasn't the voltage I was talking about. Is there a separate adjustment for NB-CPU voltage? These systems have a NB-CPU and a "NB" chipset (though that's a misnomer as the northbridge is on the CPU). The NB-CPU also has a multiplier associated with it. Stock for your CPU is 1.8 GHz (= 9x). If it's keeping that multiplier then the NB is running very fast at this point and may need changing to 7x or 8x as well as a voltage boost.With this board you can change vDimm and vCore. Is that how you say it?
It means, in english that the voltaage can be changed on the CPU and RAM, though it needed a BIOS upgrade for this feature.
Right now I'm panicking. I can't get PCMark Vantage to finish it's two GPU tests and I'm not sure why. I've past multiple 10 minute tests in OCCT, but this program must be stressing the GPU more. The thing is I don't know what overclock it is, the GPU or the CPU, as I've not tested both with long time periods.
So two questions...should I switch off the CPU clock, and see if Vantage runs, thus determining whether it's the GPU or CPU to blame by process of elimination? Also, what is good time span to run OCCT tests - 1 hours, 10 mins, 8 hours (!)
You can say don't panic all you like but I want Vantage to run, so I can compare my system with stocks of better Phenoms, see if I've caught them up
Oh nearly forgot, I'll get round to RAM timings when I'#ve sorted this Vantage problem out!
Typical final test for an OC is 24 hours but interim tests I like to run at least an hour - especially if there's some problem cropping up ...
No, the 2.2 GHz speed you're talking about is the stock CPU speed. On the K10's that is quite different than the NB speed.
The NB has it's own multiplier at 9x (= 1.8 GHz) except for the 9x50BE's, which both run 2.0GHz. Other names, maybe Processor NB or something else similar - all the names I've seen have "NB" and "CPU" or "Processor" in the title. It may not be there on the non-BE chips but I thought it was on all the K10's. Maybe it's a matter of chipsets and BIOS ...
I'm glad you found the voltage - our posts must have crossed electronic paths. A slight increase in NB voltage probably won't change the CPU temp much. Higher increases can, though.
The BIOS may be changing the NB speed by itself. Have a look at the upper right side of the Memory tab in CPU-Z - the NB Freq should be listed there ...
And you're still running the 255 MHz clock (CPU @ 2805)? That's really strange! I would expect that result with 235 MHz if the NB is still at 9X but 2115 @ 255 MHz?!? Those things don't have half multipliers ...The NB Frequency is listed as 2114.7 Mhz.
Pc mark vantage score overall : 4989 PCMarks so up with the clock, later on.
@QuietIce : HT Link (Cpu-Z) is : 1175 Mhz.
What does this mean? I'm just blindly following post number 2...
Re: Memory I found the memory clock, and found it was running at 200mhz, so I upped it. The actual speed now is : 783Mhz, and it's 800mhz rated RAM. Even though this was unclocked by accident, I would have had to start at such a low level anyway, wouldn't I?
200 is default and normal for DDR2 800. It's actually 200x4.
