ok will tryYes, that is what 'trents' is suggesting to try >> moving the fans on the side of the case toward the 'front' of the case. You say you have no way to put fan in the front section of the case and blowing into the case. Next best is on side, low, toward the front. For a test.
no good got worse,55 degrees on prime on 3.4 ghz...Yes, that is what 'trents' is suggesting to try >> moving the fans on the side of the case toward the 'front' of the case. You say you have no way to put fan in the front section of the case and blowing into the case. Next best is on side, low, toward the front. For a test.
Check out how good the mayonnaise is
Keny, U duh man. I thought you were kidding about mayonnaise. Hehehe.
Yeah it's crazy isn't it, quick tip though, don't use chocolate
Arctic Sliver 5 has a "cure" time. It's efficiency improves over (the manufacturer says) the first 200 hrs. of use. My experience is that I find about a two degree drop over the first 48 hrs. of continuous use and not any more after that.
Many people use wrong methods to apply TIM and therefore don't get good results. Kilyan, describe to us how you applied the AS5. Did you try to spread it with your finger or a straight edge or something? That is the wrong way. How much did you apply?
