- Jan 10, 2012
he has it set with a 2600mgz cpu/nb and a 2000mgz htt.
kilyan, i think to might try running both of these at 2000 or so.
CPU/NB doesn't improve the CPU overclock, it improves the speed at which the CPU can run you're memory, resulting in a better overclock in general, not just in CPU clock speed, and ht link will not improve you're overclock on a Deneb chip, but I think what caddi is thinking is that if you knock the NB down you to stock you can then reduce the voltage to the CPU/NB in turn buying you a few degrees of breathing space on the core
My comment is focused on getting his core temps closer to 55c from the 59c he has posted, not raise his clock. i think he is interested in game performance and that comes from the gpu for the most part so he should never see core temps at 59c doing that.
Some clarification is needed here. Increasing the speed of the CPUNB improves memory performance but does not result in a higher core speed overclock and may even have some limiting effect on the overclock. Lowering the CPUNB frequency and voltage may shave off a little on the temp and can therefor may allow you to push the core frequency overclock a little higher. I think what Keny meant was that overclocking the CPUNB improves the overall performance, not the "oveclock in general".
