I'd recommend Prime95 + select "Blend" then select custom to run the same size FFTs (same work being done) and then select 80-90% of available ram. That way it is like maximum Prime95 Blend.
If you really want to test CPU only, Small FFT does a nice job, calculations fit in CPU cache and CPU heats up more... but if you are borderline overheating in Blend, forget even trying.
Prime95 is generally recommended for AMD platforms for testing both the CPU (On K10, FPU is really stressed hard) and DRAM at the same time, and doing it well, since it gives several error-outs.
Common are:
"FATAL ERROR: Final result was 16295BCF, expected: C75824DB" FP error, cores
"ROUNDING ERROR:..." Memory error, memory subsystem (DRAM, or IMC also Integrated Memory Controller also "CPU-NB")
"ILLEGAL SUMOUT" <---integer error, cores...more popular on the new AMD FX CPUs and not these
Until you get cores dialed in, leave HT and CPU-NB at 2000.
