I have googled and seen threads on various forums where some were able to easily OC this CPU to 108 FSB and 34 multiplier. The best i can do stable is 106 FSB and 33 multiplier. I've added screenshots of my bios (v1102) at current stable settings. When I try to increase above these settings I get an error on Prime95 saying "FATAL ERROR: Rounding was 0.5, expected less than 0.4 Hardware failure detected, consult stress.txt file." I first tried the multiplier and increased CPu offset voltage, VDDNB voltage, SB 1.1V voltage, APU 1.2 voltage, (one at a time) at least 4 settings above current (i chnaged only one voltage up 1 setting at a time and then retested..then I tried the next voltage and so on) and still I get the same error. Prime 95 fails for the second core (1 blend test running against each core) as soon as that second blend test starts. I then tried to increase FSB to 107 and got the same issues. I have added snapshots of the GPu overclock (800mhz) and ram settings. I'm getting 60FPS and a score of just over 1500 on unigine heaven dx11 benchmark right now with current settings and 33.75 FBS on Cinebench 11 opengl as well as 4.12 CPU. I may have reached the limit of this current CPUs OC capabilities but wanted to ask if anyone could think of any ideas to try and get a bit more OC. I've never done this before and am scared to volt up too high and fry CPU. When I ran PRIME 95 I was getting 55 degree max core temp although it was only on for about 4 minutes when i got the error.
thanks for any help or suggestions.
