find you motherboard manual it will be called cmos or rtc, real time clock.
also be sure your 4 or 8 pin cpu power connector is well plugged in.
Not catching exactly what you meant.Ok, so I got all my parts, tried to put them together. But the system wont boot up to let me see the bios. I followed the instructions exactly. The mobo has lights to show what is plugged in. It registers the proccesor, but says that the gpu, ram, and ssd are not there. I tried switching the ssd for the hard drive, the hdd is getting power bc i can hear it. BUT it still isnt registering on mobo lights. Can someone please help because i have no idea what is wrong.
Sounds to me like bad CPU, or pre-BD BIOS, or the board is dead......The mobo has lights to show what is plugged in. It registers the proccesor, but says that the gpu, ram, and ssd are not there. I tried switching the ssd for the hard drive, the hdd is getting power bc i can hear it. BUT it still isnt registering on mobo lights. ...
Look at the sticker on the board. Last numbers are the BIOS version. If it's 402 then you need to do a Bios update, to 705 or 810, to use the new AMD FX cpu. I had to buy a semprom am3 version, do a BIOS update and after that the system booted ok. Mail or phone to this company was of no use. After the update you get a great system. On the phone they told me that every barebone is verified for compatibility. Someone missed this needed update to get the system to recognize the new FX cpu. Verify the sticker for new board or be prepared to a little fiddling."
Read more: http://www.buzzillions.com/reviews/asus-m5a99x-evo-amd-fx-6100-cpu-bundle-reviews#ixzz23lmYhJ2i
@trents and daveburt
His PC would be turning off if there was a short I would think.
It looks to me his board is hanging on CPU_LED, from what he says.
The lights on the board aren't to show what is plugged in, but what stage of the boot initialization sequence the board is on for debugging.
Hello, I'm kinda new to the whole pc building also, but when I called asus (and by the way we have the same board) they told me to only use on stick of ram and only have one drive for storage hooked up upon first boot up, hope this helps!Tried moving the little pin thing, then tried removing the battery, after moving the pin thing back. Still wont boot to the bios menu...
