AMD does not support triple channel memory. Dont confuse DDR 3 with triple channel memory the IMC isnt strong enough ordesigned for it thats more of Intel teritory. I am sure someone more knowlegable than me on memory can tell you the difference.
If he has a motherboard speaker that would be useful too to plug into the front panel header.
I (personally) want to know if it is beeping, and if it isn't beeping with RAM inserted, if it is without it...
I do have a speaker for the mobo. it doesnt beep ever....
0901 is the same bios version as mine and it should work just fine.the last four digits are 0901. Will that work? or does it go in reverse order like 1 is newest, 1000 is oldest?
asus said with that motherboard to not only use one stick of ram upon first boot, but also make sure you only use on type of storage until you load windows, so make sure you just use either your ssd or your hdd don't have both hooked up on first boot.i tried 1,2,3,4 stcks of ram. and moved them around etc.
