Now CPUz CPU Tab shows the FSB/Bus speed to be 200 like it is supposed to be when some adjustment has not been made. It was showing 189 not 200 before and that made me suspicious the "bios overclock" setting was not correct.
It shows the ram "speed" to be at DDR1066 which is okay for now because you have to overclock the X2 250 cpu by FSB and the ram speed rises with increased FSB. But it shows the ram timings as 8, 7, 7, 20, 27 2T and they should be 9, 9, 9, 25, 34 and 2T would be my choices from your capture of CPUz SPD Tab.
After those memory adjustments you can begin to add FSB/CPU Frequency or whatever you bios calls the FSB , you can move it to 205 and the cpu speed and ram speed will both go higher and then test with P95 Blend mode for 20mins and post up the three CPUz captures and the HWMonitor that was open on desktop before/during and after P95 blend so the Min/Max Volts and Temps will be visible to us when you post to forum.
